Originally Posted by
LivesNearCostco
Washburn: I have a theory about this, that when your coolant is a bit low and you turn on the heater, it opens a valve to route more coolant to the heater core and that triggers the low coolant light. The theory could be pure garbage though, since that would imply there are some air pockets in the heater core (or its hoses) when you're not running the heater, and we know that properly bleeding the cooling system is supposed to eliminate all bubbles except the one at the top of the expansion tank, right?
But you said it came on when the weather was cold. I'm curious if that was because cold coolant shrinks or because you were running the heater. If you always (or never) run the heater and it only came on when the car was cold, maybe it's just thermal expansion with a warm engine raises the level enough that it doesn't trip the sensor.
