Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    OK....excellent. I thought you said...it was jacking up the car?
  2. #22
    Aug 2011
    San Ramon, Calif. Bay Area
    Yea it was jacking the car, thats when I backed off to look for your thread, Pip helped lasted night but I decided to try again this morning after coffee and read your post again and again to make sure I was doing it right, was gonna go for method #1 but that upper torx screw would have required me to move headlight to get to it so I opted for #2 with the micarta pry...
  3. #23
    Ok... Well done. Glad it's fixed.
    HTC Thunderbolt+TT
  4. #24
    Jan 2011
    SoCal
    Replacing the entire cooling system at home next Saturday. Will try to take good pictures of the steps if I can.
    2004 ZHP Saloon
    Location - CA
    Very Proud Owner
  5. #25
    Apr 2011
    Dallas
    Can the Torx screws in question be removed from above or does the car need to be elevated and the splash panels removed?
  6. #26
    Just go straight in from the top. You can get to them both.
  7. #27
    Apr 2011
    Dallas
    Great, thanks. Need to replace a tank today and hoping to be able to do so w/o raising the car or doing anything from below. Coolant flushed recently and therefore no need to access drain plugs.
  8. #28
    Aug 2011
    Las Vegas, NV
    Nice Info!
  9. #29
    Jan 2013
    Central California
    Won't coolant run out when you pull the tank loose? I would think you'd want to drain the coolant into a container first.
  10. #30
    Apr 2011
    Dallas
    In this particular case it was already mostly empty due to leaking. And of course everything below it was already wet, etc. But normally yes, you'd get under it and drain it at the blue drain screw.
    This one was something I'd never heard of in the world of leaking E46 expansion tanks. Will probably start a new thread topic.
  1. Expansion Tank Cap Replacement
    By BCS_ZHP in forum Mechanical | Troubleshooting
    Last Post: 02-11-2014, 12:26 PM
  2. How does the coolant expansion tank work?
    By Dave1027 in forum Mechanical | Troubleshooting
    Last Post: 02-15-2013, 12:17 PM
  3. Expansion Tank - 9 months old and leaking already
    By CERF04ZHP in forum Mechanical | Troubleshooting
    Last Post: 01-27-2013, 06:12 PM
  4. Replies: 3
    Last Post: 09-15-2011, 11:00 AM
  5. Expansion Tank Took a Dump (pics)
    By tripod06 in forum Mechanical | Troubleshooting
    Last Post: 07-06-2011, 11:45 AM
