Results 1 to 6 of 6
Thread: Sqweaky sound?
    Sqweaky sound?
    Hey guys! Well now that I have wheels that fits, I feel like my brake pads are worning off (not sure). Upon breaking, I can hear a loud sqweaky sound in the front end of the car, sort of coming in the front end of the car. I was wondering if I'm right about the brake pads and such, where can I get the "cheapest" yet best kit? The sound only happens when I brake, which is quite bothersome, and I am very worried. Any help would be greatly appreciated.
    Could be that they just need lubricated. Could be that you need pads. I would think if you needed pads that bad, that the brake pad wear sensors would give you a warning.
    How about take the tires off and look?
    How many miles on current setup?
    HTC Thunderbolt+TT
    I'm currently running 83k right now. And, would the sensor show up on my dashboard?
    32.8 N, 117.3 W
    this is the warning light:
    as for getting replacements there are tons of choices. use the affiliate link at the top of the page (or click here) and go to AutohausAZ. Pick your car, then go to > Brake & Wheel Hub > Brake Pad Set
    under that page you should find BMW brake pad lubricant and 3 manufactures for pads (Pagid, Bosch & Mintex). If noise is the issue you're looking to kill and you're not tracking your car I would go with the Bosch QuietCast for $49.39 (either front or rear set, total of $100 for all 4 wheels)
    you should get the lubricant either way, you'll use it eventually and besides it's only $1.56. You will need 2 per car.
    If you're thinking of going for higher performance brake pads let us know so we can give you other ideas.
    If that's the warning, new pads, and sensors need ordered.
    HTC Thunderbolt+TT
    32.8 N, 117.3 W
    I was just showing him what the warning light would look like IF it did go off, but yes, you are correct as to new sensors needing to be ordered as well.
  1. Now a Clunking Sound at Low Speed
    By echo46 in forum Mechanical | Troubleshooting
    Last Post: 11-25-2011, 05:14 AM
  2. Hissing sound from ac
    By xtremecro in forum General -- ZHP Related
    Last Post: 10-11-2011, 03:53 AM
  3. MKIV w/HK sound audio
    By 06ZhP in forum Audio | In Car Entertainment (ICE)
    Last Post: 08-27-2011, 08:33 AM
  4. Flat sound
    By cparker in forum Audio | In Car Entertainment (ICE)
    Last Post: 06-08-2011, 10:06 AM
  5. weird sound
    Last Post: 05-04-2011, 08:31 AM
