Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: UUC Flywheel and M5 Clutch Kit (anyone use it?)
    Quote Originally Posted by SoarinZHP View Post
    If one is capable of doing the job themselves, I'd say try it and see if you like it. Then you'd know for sure and could easily go back to a stock setup. I was not comfortable with my mechanical skills and had a shop do it - plus I needed the car back ASAP. At the time I was not (and still not) in the financial position to have a clutch replaced so frequently.
    Yea, I do all my own work and work on BMW's as a side business. But I don't want to do it more than once. The stocker went 138k miles, maybe I should stick with stock.
    And wow, that Grand Am flywheel ain't cheap. $900, ouch!
    Baltimore, MD
    Grand-Am Fly should outlast anything you are gonna throw at it on the street! Would make a nice tax-return present
    Porsche 944 Turbo Build
    My ZHP Build 2004-2014 RIP
    Do you stock ZHPer's experience any chatter in gear at low rpm or in neutral at a standstill? Because I've only heard of the Stock Flywheel Chatter issue upon shutdown with the car in gear/clutch depressed.
    I get the chatter when in neutral.
    Sent from my iPhone 4S from Tapatalk
    A little chatter in neutral. At shut down with the clutch depressed or in neutral... Always.
    A Venza just isn't the same as a ZHP.
    Ocean County, NJ
    No neutral chatter.
    Shut down in neutral, yes, but not if clutch depressed.
    2005 ZHP, Alcantara, Silver Cube, Nav, Sharked, BMW Perf Intake, BMW Perf CF Strut Brace, CF Valve/Fuel Rail Covers, Shadowline Grills, CF Splitters, Fog Light Inserts, LED Interiors/Plate Lights, Euro-mirrors, CDV Delete, Beisan vanos, GAS DISA, BP Coded
    2017 Alfa Romeo Giulia Q4; Sport Package, CW Package, Nav, Sunroof
    Baltimore, MD
    Those responses are why I think this is limited to Six Speed transmissions. But it is not a bad thing, no harm is done to the car.
    However with the extremely lightened flywheels, they are meant to have a load on them at all times, except when starting the race...You can get away with a few pounds on a DD, but I would never go as low as 8.5 pounds...That's ridiculous.
    But the dual-mass flywheel is for the mass populations, so there are plenty of upgrades available for the enthusiast owner, but normal weight with a single mass is the best option for a lightly modded Daily Driver, IMO.
    Main County
    Bump. So are there any Lightweight SMF's still in production? Would love 20lbs, but the one in this thread seems discontinued now.
    | My YouTube Channel | Instagram (WIP) |FS: Steering wheel controls |
    BMWCCA GGC: 530872
    "You canít connect the dots looking forward; you can only connect them looking backwards." - Steve Jobs
    May 2016
    Chicago, IL
    I DD a 15lbs flywheel, I'll have to check in the records who made it, but even though it was a learning curve I don't see myself going back from it. 8.5? Sounds a little extreme for DD purposes, the neutral chatter as is is already quite obnoxious, but imo it adds character :P
    Interested to see which you go with, always good to remember this stuff for the next time mine needs to be replaced(knock on wood)
    Hotchkis Sport sway bar | ECS Tuning Carbon Fiber front strut braces
    Michelin PSS | Blizzak WS-80
    Main County
    Quote Originally Posted by Prestovie View Post
    I found a 14lb from clutch masters but can't find anything between 14lbs and 25lbs. If you know something I don't then please let me know!
    BMWCCA GGC: 530872
    Jul 2013
    Roseville, CA
    SPEC makes the SB07S 20# steel single flywheel for the ZHP.
  1. CLutch an such
    By Muggzie in forum Performance
    Last Post: 12-05-2011, 12:02 PM
  2. Clutch Rattle?
    By redwagon in forum Mechanical | Troubleshooting
    Last Post: 11-08-2011, 09:01 AM
  3. Clutch kit
    By Johnmadd in forum Maintenance
    Last Post: 09-21-2011, 06:24 AM
  4. Dual mass flywheel
    Last Post: 08-10-2011, 02:46 PM
  5. Bad clutch?
    Last Post: 04-23-2011, 10:55 AM
