Just look at your headlight lens...in the lower corner it should say ZKW like on my avatar lol
If so, they are more than positively burnt to a crisp
Yes, the headlight lens will have a small ZKW symbol with a circle. If not then you will see a small AL symbol instead on your headlight lens.
If you have the "famous" ZKW headlight assembly then all you need to do is pop the Xenon cover and look inside and you will see the projector assembly. if it looks like the following pictures, then you have the same problem the majority of us do. In that case, welcome to the club...fortunately, there is a solution as I and others have found. It's up to you which path you want to go from there.
Here are a few pics...
You can see in the last two pictures where the upper half of the ZKW projector bowls are burned out by seeing the brown/black coloring...should be silver like the bottom part. This is what is causing your diminished light output.
Sounds like another candidate for FX-R retrofit!
