Well it's been a week and a half since I purchased the XI and I must say she's running pretty fresh right now. Here is a list of what I have done so far, and yes my lower back aches from bending over and I have removed the air box so many times I think I can now do it in about 15 seconds flat.
Bleed brakes with ATE Super Blue/change oil and filter with Mobil 1
Clean MAF
Replace AC Belt
Replace lower intake boot, replace power steering cap gasket
Replace drive belt, ac pulley, deflection pulley, water pump pulley, power steering pulley, and tensioner pulley. Replace air filter with OEM. Replace hood roundel and swap out original kidney grills with matte black grills.
Replace wiper blades
Change spark plugs (NGK Laser Platinum), change front and rear differential fluid with Redline 75x90, change transfer case fluid with Redline MTL.
Replace fuel filter and fuel lines running two and from filter
Replace upper intake boot, "F" fitting, and replace DISA
