I have a slight leak in my cooling system. It is at the radiator outlet switch, which is located on the lower radiator hose. If you are leaning over the front of the car, looking into the engine bay, it is directly below you, to the left of the radiator, right above the plastic liner/guard. It is seeping. not much, but a little. If i press on the connection, it weeps a little more. has anyone had this issue? I ask only because if i remove the switch, it is going to start leaking coolant. Id like to know what im getting into before i remove the switch. Maybe there is a seal ring that is bad? Anyone seen this before?
