Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    spencers Guest
    All I can think of for reasoning to do something like that, is if a worn suspension component throws the alignment off. But I can't think of anything where that may necessitate the need for extreme camber. Perhaps a blown shock or worn control arm bushing?? Especially on one side, cause it seems like the the drivers side has more of a change than the passenger.
    I'd love to hear the explanation when you find out from the shop
    Quote Originally Posted by zj96sc View Post
    What am I missing? How would there be any case (ignoring bent components) where the car could NOT be dialed to factory specs with the pins in? Wouldn't that be how she rolls off the line?
    The only way you CANNOT reach factory specs, with FSM pins in place, is if you are lowered.
    A,GA
    ah, ok. that's what i was thinking. just confused by the way you guys said it.
    Jan 2011
    Martinez, CA
    Thanks everybody.
    The car handled better before! And I agree, if they couldn't get the car aligned, they should have found out the reason why. Like you said, worn shocks, bushings, bent control arms or whatever. I'm an adult. I can take that sort of thing. But, to blindly drill a hole is out of the question. Especially since you didn't contact the customer before making such a radical step.
    Once they drilled into the strut towers, it's done. Nothing I can do about it except try to get it set up properly and be compensated for it.
    There is a local BMW/Mini only shop, Edge Motorworks. I've taken my car here for a lot of the stuff I can't do. But, this time, my tires were in really bad shape-bald on the inside with the tread showing and REAL scary in the rains we just had, so, I was in a bind and went with Wheel Works since they were close to my work. In fact, I wasn't even planning on having them do the alignment. But since they had a 12 mos/12k deal, I could replace my bushings (which I was planning on) and take it back and they would re-align it for free. Not now. NEVER taking it back again.
    I have an appointment on Monday to take it to Edge (they're mentioned in the Die Fleuster Bombe-BMW Newsletter) for their finishes in the 25 hours of Thunderhill.
    Johnny
    Johnny... They did not drill the hole in your strut tower.
    The hole is there, on every E46. It is there, to receive an alignment pin in the front shock mount. The "pin" is what they removed, to alternate camber.
    HTC Thunderbolt+TT
    Oct 2011
    Silicon Valley
    When I got my car, one pin was missing. I punched out the other one with a nail setter and a hammer so I could make camber more negative on both sides. (I think on the E46 M3 you unscrew the alignment pin instead of punching it out.) Whether they used a punch or a drill, it looks like they were a little sloppy and nicked the paint around the (pre-existing) holes.
    Jan 2011
    Martinez, CA
    Well, whether they used a punch, hammer, wrench or a drill, they did a piss-poor job of it. Aside from replacing the part underneath, there is no way to get it back to original.
    I am not slammed. I am on the stock suspension. At 92k miles, I KNOW I have worn control arm bushings. Don't know what else needs to be done. What they did should have been the last resort. They should have suggested repair/replace this or that. Having them do what they did should have been my call. They didn't let the customer decide. It is common for most shops to call and get some sort of a verbal o.k. from the customer before doing any extra or additional work. Most of the time, it's due to added cost. I think they should do the same before making any permanent modifications to a car too. It is, in my book, common courtesy. The other thing is, if they had to do all that to get the car aligned, why does it still pull to the right? It tracked straight and true before.
    In Wheel Works defense, the Manager called to try and resolve the issue. I will be bringing it by at lunch on Monday for them to look at only so they can assess the damage. Then, it's off to Edge Motorworks on Monday afternoon. I will get an impartial third party opinion on what to do. I will take it from there. Hopefully Wheel Works steps up to the plate. Just how they plan on doing so is yet to be seen.
    Jan 2011
    Martinez, CA
    Update to my experience.
    I was contacted by Tom, the manager, at Wheel Works. I calmly explained the situation and once he saw the pictures of what happened, he understood my gripe. He explained that they removed the alignment pins from the strut mounts in order to align the car. This would have been okay had it been the last resort and the final step in trying to get the car to align. My gripe at this point was that they made an irreversible (except for replacing parts) change to my car. In the process, they also did a bit of damage to the surrounding paint. Since they had such a hard time aligning the car, they should have addressed any underlying problems first-worn bushings front & rear. I knew I had worn bushings and planned to replace them (which was later confirmed by an outside shop). In speaking with Tom, who was very calm and professional, we both agreed that there was a breach of my trust and confidence with Wheel Works. Although he made a generous offer, I declined since I felt it was not fair to them.
    All in all, I have to give props and kudos where due. Tom and Wheel Works really stepped up to the plate. They wanted to make sure that I was happy and that I would consider coming back for future business and recommend them. While I am still hesitant to bring my car back, I would not hesitate to recommend their work or to bring the wife's car here.
    Wheel Works has a history with me. I have always been happy with their service and the level of work over the past 20+ years or so. The Walnut Creek store in particular. I've taken a quite a few of my cars there.
    If the same thing happened to me again, I would not hesitate to write another bad review of any company/business. I believe in the power of the internet and that we all can benefit from forums such as yelp for good and for bad. This includes businesses. How else can they improve/change unless they get candid and sometimes unbridled reviews of their work/business. Times have changed and the speed at which word of mouth is spread happens instantly. Again, good or bad.
    Sorry for the long post, but I felt I owed it to Tom and Wheel Works to explain the situation in detail and the steps they took to remedy it.
    In this instance, the bad was offset with good. If nothing else, Tom and Wheel Works have won my respect for how they handled the situation.
    Johnny
  1. Headlight stops working and then works again.
    By Go Horns! in forum Mechanical | Troubleshooting
    Last Post: 12-12-2011, 06:16 AM
  2. BMW Performance Drilled Rotors
    By Mtnman in forum Product and Storefront Reviews
    Last Post: 10-02-2011, 01:54 PM
