Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Maine
    Coolant light came on...
    I was just pulling out of the touch free wash on Saturday, and through those high speed driers, and my coolant light tripped on. So I pulled over to the side, shut the engine off, and checked the level and everything was fine. Couldn't really see if there were any leaks because the undercarriage was still wet. Got in and started the engine, no light on. Drove 10 miles home, check fluid level again (ok) and check out underneath, bone dry.
    Suggestions?
    HTC EVO / Tapatalk
    BMW Perf. Gloss Kidneys | UUC DSSR | B&M SSK | 35% tint | AL Headlight Retrofit with ZKW Lenses | Tri-Color Coby Wheel | Aux Input
    Keep an eye on it.
    HTC Thunderbolt+TT
    Apr 2011
    Middle River, MD
    The sensor could be faulty. Best bet is to check it every couple of days. Once a week is best.
    Also, be careful checking coolant on a hot engine!
    Kansas City
    I agree if the light is coming on I would check it daily for a week or 2... if the fluid level never changes I would start thinking sensor
    Mods: Smoked corners, smoked side markers, smoked tails, 35% tint, CF kidney grills, debadged, angel eyes, 3000k HID Fogs, OBX exhaust, Sharked, solo werks S1 coilovers, front and rear strut brace, AUX cable
    "I'd rather lose by a mile because I built my own car, than win by an inch because someone built it for me"
    Fayetteville, NC
    Sudden drops in outside temp can trigger the light even if the levels are ok.
    or even sudden spikes: High heat drier --> plastic expands --> (tank bigger) --> level drops a bit --> light?
    Maine
    Got it. Thanks fellas.
    Maine
    Okay... now after a couple weeks of analysis, here's what's going on: I start the car in the morning, light pops on after driving for about 5 minutes, stays on for a minute or two, then shuts off... I cruise 40 miles down the highway @ 80mph, get off at the exit for work (or home), and as soon as I get back down to stop and go traffic, light pops back on for a minute or so, then shuts back off. Very strange. Does it every day now. Level is fine.
    I bet you have a small crack in your expansion tank. These indications are nearly identical to mine. I believe the crack would swell, due to temp....or pressure in the tank......then close back up. Super slow leak.....never noticed any "leak" per se', then finally found it when I pre-emptively changed out the tank.
    Have you completed a really good inspection of all the problem area's?
    nike001 Guest
    I bet you had your heat on..
    Amirite?
    Oct 2011
    Silicon Valley
    What does your ET float (level indicator) look like when the engine is completely cold?
  1. Low coolant light on a few times...
    By Washburn in forum Mechanical | Troubleshooting
    Last Post: 12-01-2011, 10:34 PM
  2. Coolant Bleeding
    Last Post: 10-14-2011, 07:12 PM
  3. Power Steering and Battery Light and Coolant all went to hell
    By tripod06 in forum Mechanical | Troubleshooting
    Last Post: 08-22-2011, 01:01 PM
  4. Hot Coolant?
    By Grex101 in forum Mechanical | Troubleshooting
    Last Post: 06-11-2011, 07:49 AM
  5. My low coolant light came on today
    By 3ZHPGUY in forum General -- ZHP Related
    Last Post: 12-20-2010, 06:49 PM
