ordered the stage III ECS tuning kit and I'm told that 3 1/2 hrs in, they realized there was a secondary thermostat that isn't included. Do I need to buy this elsewhere or not need to use it or what?
Call me Seth
Sec thermostat? What p/n?
HTC Thunderbolt+TT
Bwuh? I've only ever heard of the one t-stat; think they meant the lower radiator hose's temperature sensor? Part #4 below (P/N 13 62 1 433 077)?
no it looks like it was something that goes inside the expansion tank maybe?
Call me Seth
coolant level sensor?
number 5:
I did not replace mine on either ZHP during cooling overhaul........should I have?
Bingo; that's the only thing (esp. a "sensor") that goes in the exp. tank. Most (all?) coolant kits don't come with a new one; I didn't replace mine, & IMO you don't need to replace that unless it's known to be bad. (Or if you break it during the overhaul; it's fragile!)
You could have. My kit came with new one. Only time will tell if you should have replaced
HTC Thunderbolt+TT
The level float! Nawww, that comes with the new expansion tank. If you have an automatic transmission, there is the other thing that connects to the bottom of the tank, I think it's the A/T cooling thermostat.
