My windshield washers do not work, it has fluid in there. Do you think the little pump could be bad?? Where is it located and how do I change that sucker? I have never had a problem like this.
-JJ
2005 Zhp Sedan (Sold), back in the 2004 Allroad 2.7t
Good call on the fuse. I will try and check that tonight when I get home.
-JJ
This may be stupid but how do I know which fuse it is?
-JJ
Could just be clogged....but check fuse first....49, 52, 59....
if you have to replace it, it is super easy. no sweat. also, no expensive (for once) Ive done it....sure others have too
09 135i Msport 6mt
04 330i ZHP (sold)
David
Be careful messing with the fuses. I had the same problem on the wives 325CIc and put a fuse in the wrong slot. All the brake lights came on and I ended up taking it in. I usually check fuses with my test light. I connect the clamp to some metal object loke the door hinge. Then I touch the point to the both sides of the top of the the fuse. The light will come on on both sides if the fuse is good and the ignition is on or in the second position. There is a very small opening in the fuses that you can get the test light in. This time I was to lazy to stand up and walk over to my tool box and grab the test light. I saw the cool little fuse puller and thought ahh this el work, NOT, OH SHIT. god I hate when that happens.
I think the pumps are attached to the washer box.
Brembo Rotor
Thanks Dane, I will try those tonight. Now I am nervous, 3zhp killed the should be easy thought.
-JJ
Try all the basics like the above mentioned fuses and stuff first before buying a new pump. Mine was blocked by some sand one day. Do you have headlight washers too?
No headlight washer. I will try the fuses first cause I cannot hear it trying to work at all.
-JJ
