Good to hear!
Good to hear!
I had acquired two (1 under each seat) of the "incorrect" boxes with brackets and screws from ECS and had not installed them when I first read this thread. So I was pretty bummed. But while installing my Pedalbox last week, I figured I would go ahead and at least install the first aid box brackets and wait until I could find the correct boxes. For giggles, I went ahead and tried to install one box under the passenger seat and instantly encountered the problem described - box is too deep and hits a bar under the seat. Out of a bit of frustration, I smacked the box pretty good and somehow, someway, it snapped into place! I could tell the rear of the box dropped down a bit to clear the bar, but it was otherwise secure. Hard to describe but to me, it felt like the box fit as intended. I reinstalled the seat, tested all of the seat movements, including the thigh bolster, and everything works perfectly.
So what the hell, I went ahead and did the same on the driver seat. Same result, however, that box took a bit more effort and didn't seem to fit quite as naturally as the passenger side. But everything works properly, go figure.
One thought for convertible owners - the bracket actually takes three (3) screws - front left, front right and rear - though the 2 front screws are probably adequate. If you omit the rear screw, or don't tighten it fully, there might be enough play in the bracket to allow it to drop down a bit so the rear part of the box clears the seat bar. I installed the rear screw tightly on both of mine and it still "fit" but as I described, I had to force the boxes into place.
Glad it worked for you. It seemed clear to me that the one I bought originally wasn't going to go on without interference. And luckily John in VA pointed out, the convertible does call for a different box (the one I just finally installed) that doesn't have the bump out on the bottom that hits the bar.
So sounds like 2 good outcomes
Pete
