I don't see the high performance coils doing anything better than the OEM ones.
I once had high performance wires installed in my E30 (used cap and rotor at the time) and they made no difference.
My car has been running rough at idle for the past few days and now my Service Engine Soon light came on. In researching this a little on the internet it looks like it could be a bad ignition coil or spark plug. You guys have any comments on this? Thanks!
gerMANIAC
Could be. Best way to narrow down is to get the codes read.
If you get a misfire code with a cylinder #, you can swap coil packs and verify that you have a bad pack.
How long have the plugs been in?
When was the last time the valve cover gasket was changed?
I believe the plugs are original. I found some info from bmp design showing how to verify if you have a bad coil. I think I will try this first and proceed from there.
http://www.youtube.com/watch?v=z37jl4HXQjg
gerMANIAC
Well that's certainly one way to do it.
Let us know how you make out.
If you don't narrow it down with that, let us know if you get the codes read. Could be several other things besides plugs and coils.
I got an error code P0171 - system too lean...
http://www.obd-codes.com/p0171
Possible solutions listed in the attached link - anybody else ever receive this code...
gerMANIAC
Yes. Both e46's I had. It was caused by torn intake boot. Tear was on smaller hose that goes to icv.
Inspect intake stream for a leak.
HTC Thunderbolt+TT
Yep-- most likely the intake boot like DW said.
Common issue. Easy fix.
