I have just complete an overhaul of the cooling system and while driving around, I found I was leaking a substantial amount of fluid from the temp sensor.
I know there is a gasket on the sensor, that was reused, but I guess could go bad? I am able to turn the sensor in the housing slighly back and forth as well as wiggle it up and down slightly. Is there supposed to be any play in the sensor at all? Certainly doesn't seem water tight especially if the car is being driven.
Any thoughts?
