View Poll Results: Which seems the most logical way to fix the vanos?
Voters
20. You may not vote on this poll
  • Beisan System
    13 65.00%
  • Dr. Vanos
    6 30.00%
  • S54 swap... duh
    1 5.00%
Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 147
  1. #21
    Aug 2011
    The Windy City
    probably not
    Call me Seth
    If I wore panties, I'd be dropping them right now.
  2. #22
    Aug 2011
    Joliet Illinois
    Quote Originally Posted by UdubBadger View Post
    ^ same (i need both seals and rattle) which is why I'm thinking Dr. Vanos. Time is also not something I have an abundance of these days. How hard is it to swap out the entire unit with Dr. Vanos?
    I did my anti rattle without an impact wrench. I just used a socket wrench and mimicked impact wrench force by doing quick fast pulls over and over. It's kind of hard to explain lol. But I managed to do it without it
    Sent from my Nexus S 4G using Tapatalk 2
  3. #23
    It could be done that way. I would imagine a sharp rap on the handle of the wrench would work....not that I'm into hitting my tools.
  4. #24
    Philadelphia
    The cheap $40 impact wrenches from Harbor Freight are enough to do the rattle kit. I personally used Beisan's kit on my ZHP (Dr. VANOS was a lot more expensive back then, and Rajaie let me be a tester for the rattle kit). I see no reason not to go with the Beisan systems kit. IMO the hardest part of the whole repair is getting to the VANOS... which you have to do no matter what. Changing the seals and the bearing is trivial at that point.
  5. #25
    Ocean County, NJ
    ^ I disagree with both the trivial statement and the no reason to go with Dr. Vanos statement.
    Opinions clearly vary on this, though, hence the two different available options and customers who are happy with both.
    Reasons to go with Dr. Vanos, imo:
    Faster to do the job
    Less work
    Less tools
    Less risk of damage
    More convenient
    _________
    At this point in my life, I'd rather just save the time screwing around with pulling the pistons apart, checking axial play, and removing and replacing seals and o-rings- and instead just pull one unit off and slap the other one on.
    I've used Beisan before. I'll be doing the Beisan thing again on the ZHP in a few weeks. But I wish I went Dr. Vanos this time around.
    I wish this was sent with a Galaxy S3
  6. #26
    Jan 2011
    Martinez, CA
    While I personally did the Beisan seals myself (did not do the rattle as I don't have the rattle), I voted for the Dr. Vanos route. Only for the fact that the OP has limited time, tools and resources available to do the complete job himself. With the proper tools, time and/or help, I would have voted for the Beisan system.
    You DO need the deep socket to remove the Vanos unit if I remember correctly. You also need a torque wrench capable of in/lbs as well as a few other miscellaneous tools beyond the normal shade-tree mechanic (at least for me). Nothing mind-numbingly expensive, but it adds up to either a lot of trips to the store or a well-equipped buddy. Once that part has been taken care of, then the rest is relatively easy. Just takes time and (for me) patience and organization. I also took extra time to clean everything I could get at to make sure I could see if there were any new leaks etc as a result of my wrenching.
    With either case you choose, make sure you post back here with your results!
    Johnny
  7. #27
    Apr 2011
    Middle River, MD
    I have similar skill sets as the OP and I would have probably done it Dr. Vanos style.
  8. #28
    I had zero skills and did it.
    I think the bottom line is time, and sense of adventure. If you need to just get it done, and aren't really all that concerned about becoming intimately familiar with the car, then Dr. VANOS is the way to go) as others have said)
    For me.... I had the time (an entire day), a backup ride (should it last longer-no stress to get it done asap), and the genuine need/want to learn.
    With that said.... You will actually learn quite a bit about your car doing Dr. VANOS.
    Dr. VANOS, I equate to... Changing out your alternator (component replacement)
    Beisan, I equate to pulling that same alternator but rebuilding it and re-installing (component repair and re-install).
    Sent from SIGFest USA
  9. #29
    Ocean County, NJ
    +1
  10. #30
    Aug 2011
    The Windy City
    This is my 1st line of concern, I have none of this other than the slight curiosity of whats going on down there... I just know missing time, a backup plan (car), tools and knowledge/mechanical skills will cause something to go wrong and am not equipped for that.
    Dr. Vanos it is.
    Call me Seth
  1. Beisan Systems Vanos repair kit
    By Hermes in forum DIY
    Last Post: 01-29-2014, 06:05 PM
  2. Beisan VANOS Seals - Brand New
    By fauchpj in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 05-03-2012, 06:37 PM
  3. VANOS question
    By break80 in forum General -- ZHP Related
    Last Post: 09-26-2011, 07:28 AM
  4. Bad Vanos?
    Last Post: 06-24-2011, 01:02 PM
  5. For Sale (SOLD): Beisan Vanos Anti-Rattle Kit $45
    By kpro in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 06-16-2011, 10:29 AM
Tags for this Thread
