I recently took my car up to Ohio to visit family. On the 1k+ mile round trip I had a few things pop up that I wanted to run by my learned peers.
The first occurrence was that my tire pressure sensor went off for no apparent reason. I stopped in at a small mechanic off the highway and asked him to check my tire pressures and he said everything was good. I reset the pressure sensor and it stayed quiet for the rest of the trip. Is this a (fairly) common occurance?
Next was after driving off the highway in 101 heat my DSC and yellow e-brake light popped on. The manual attributed that to a failure of the system that governs them. I'm assuming that the heat just got to it and it switched off to try to prevent damage.
The third thing is that I seem to be having a recurring issue with my yellow oil light popping on. I've recently put about .5 quart of oil in (2 weeks ago or so) and have pulled the air cleaner off and didnt see any oil leaks. Is there somewhere else that I should be looking for leaking oil. I'm not getting any sooty build up on the back of the car so it doesn't seem to me that I'm burning it off.
Edit: Not exactly the correct place for this but I'm rapidly losing the seals for my rear windows (coupe) has anyone changed these out and can give me an idea of the level of difficulty\frustration that I'm likely to encounter?
