Results 1 to 10 of 13
Thread: Car wont start
    Silver Spring MD
    Car wont start
    So for the past 2 weeks I have been having issue with starting the car. At first the car would just click without cranking. after holding it for a while eventually the crank would kick in. Prior to this it did seem the car took longer to crank then normal but was cranking from the beginning of me turning the key. Today I tried to start the car however this time it seems that it wont start at all. I have power throughout the car but it seems sluggish i.e. the windows are slow to roll up and down. I looked at the battery and it is displaying green in the little window.
    Can anyone help me?
    Redondo Beach, CA
    That's almost certainly a bad battery. Car batteries have 6 cells in them internally wired in series. The green window measures the condition of the electrolyte in just one of the cells.
    You could try charging it with a battery charger but it is most likely irrecoverable.
    William.
    2006 CiC 6MT
    ZHP, Cold Weather, Xenon
    Jul 2011
    Long island, New York
    Yes, I'm also thinking bad battery.
    Aug 2011
    Las Vegas, NV
    Don't trust the indicator on your battery. I had a dead battery once with a "Green" light. It does sound like your battery is shot. How old is it? You could try trickle charing it but if its older than 5 years just buy a new one. If you can use a volt meter and check it with the car off, you should get 12.0 volts or greater.
    Silver Spring MD
    Thank you very much went to AAP and swap for a 94r-h7 was nice to hear it start so quickly.
    Aug 2011
    Las Vegas, NV
    Sweet!
    Aug 2011
    Joliet Illinois
    My car won't start now and i think it's pretty much the same symtoms. Could anyone look at this video and confirm.
    thanks. http://youtu.be/9dj_sn3WEfU
    Yeah...I can support a bad battery. Can you check battery voltage via OBC?
    Aug 2011
    Joliet Illinois
    Thanks dane. It's definitely the battery. Gave it some cables and it started right up. On my way to auto zone to pick up a new battery. Any suggestions on which battery I should to get from there?
    Sent from my Galaxy Nexus using Tapatalk 2
    Huntsville, AL
    If they don't have it try NAPA, the last one I replaced, I tried Sears for a Die Hard and they didn't have the correct size, I also had some other shop call around with no luck.
    Brembo Rotor
  1. wont stay running
    By Johnmadd in forum Mechanical | Troubleshooting
    Last Post: 12-24-2011, 03:26 PM
  2. Won't start
    By midlandtech in forum Mechanical | Troubleshooting
    Last Post: 12-20-2011, 06:04 PM
  3. Where to start?!
    By BustedBoat in forum General -- ZHP Related
    Last Post: 02-17-2011, 10:47 PM
  4. My Snowflake Wont Leave Me Alone....
    Last Post: 01-08-2011, 07:34 AM
