Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 162
Thread: Battery for BMW E46
    Battery for BMW E46
    I recently had my battery tested and determined that is getting pretty weak. The car starts fine, but the cold crank number was 400-something while the spec was 600-something. That, and my shark injector install failed because the battery failed to maintain proper voltage. It's time to change.
    What is the ideal battery to use? I'm seeing people using the Autozone 49DL. Has anyone here replaced their factory original and with what? Experiences?
    Lebanon, OH
    Typical BMW batteries are good for 5 to 7 years...just as a data point.
    This is what I had in TiAg 325i....and can't believe I don't remember what I put in the zhp....but I think its the same.
    I never had heard of a bad report on the 49DL however.
    Sent from my Droid using Tapatalk
    "Flame suit NOT REQUIRED!!!"
    Ocean County, NJ
    Did the 49DL for the 325. No issues for the 18 months it was in until I sold it.
    I certainly wouldn't hesitate to go that route again.
    2005 ZHP, Alcantara, Silver Cube, Nav, Sharked, BMW Perf Intake, BMW Perf CF Strut Brace, CF Valve/Fuel Rail Covers, Shadowline Grills, CF Splitters, Fog Light Inserts, LED Interiors/Plate Lights, Euro-mirrors, CDV Delete, Beisan vanos, GAS DISA, BP Coded
    2017 Alfa Romeo Giulia Q4; Sport Package, CW Package, Nav, Sunroof
    Sounds good, I'll get the 49DL. How much was it?
    Lebanon, OH
    The batt in my car now was $140.00 at Autozone. I'm going to post a pic of it later. I want to say the 49DL was like $70.00?
    I bought the 49DL today. It fit fine, but it was a pain in the ass trying to connect the really fat positive cable cluster, the one with the explosive charge on it. I can't tell you how scared I was to touch that thing, but eventually ended up slamming the thing into place because of it being such a tight fit.
    It works beautifully though, and has a much higher cold crank rating than the OEM. It cost me about $100 or so.
    Ocean County, NJ
    Good deal, man. Any issue getting the vent hose squared away with the limited space?
    Quote Originally Posted by kayger12 View Post
    No. The vent hose would not have fit as-was, but the battery came with a vent hose for it, and I just attached that hose to the one that came from the car. It wasn't a problem as there was enough slack, and there was enough room to make sure that it wasn't pinching. The battery clamp fit perfectly as well and holds the battery down tight.
    Ocean County, NJ
    Cool. Same deal I had when I switched it out in the 325.
    I like to upgrade to a red top or better yet a yellow top optima battery whenever I get a dead battery, and it doesn't need the vent hose becauase it is totally sealed. You can mount it upside down if desired. These are the best out, so why not. I believe they cost about $140 - $160.
  1. Need some Battery Replacement pointers
    By kpro in forum Maintenance
    Last Post: 05-16-2011, 09:26 PM
