I will make a video asap. Does it have to be a cold start or just idle as normal? I haven't even turned my ac on yet, just heat occasionally.
Don't think it matters. Key is to see if it gets worse with a/c.
My bogging was bad without a/c, but not bad enough to stall. That only seemed to happen with a/c.
Also, turn your temp way down so the compressor actually kicks on.
I don't know if we every got a straight answer about whether the green snowflake light means the compressor is on, or just available if the auto climate system needs it...
Yes.....snowflake button is on....compressor kicks on....
Did you have your foot on the gas?
Nope, didn't touch the gas.
Sounded like rpms went up to 800/900....then came back down to 600/700.
I didn't see a stumble. That evolution looked normal to me.
Sent from my Droid using Tapatalk
Agreed. I'd do it again, and then with a/c on give it just a little touch of gas. See if you can get that stumble. Not sure if it will work in neutral. Might have to be under load to really make it happen...
Any objections to trying fuel injector cleaner? Never used it before, but someone suggested I try it.
