Not sure on the injector cleaner. Never used it but don't think you could hurt anything. DW?
Only thing is, if you had clogged injectors that were so bad that the car was stalling, I would think it would definitely throw a code...
I check it again today, no new codes. Good old oil pressure switch is still there of course.
Switch is still there?
Sent from my Droid using Tapatalk
Yes, and the code for it. It comes back after clearing.
I went quickly through the thread again and didn't see the code. Apologize if I missed it...but can you post again?
It's in the INPA video I made, I didn't copy out the error in here. I'll get a text version of it next time I plug in.
Here's the exact error:
Error: (1)1 Nr: 10303___283F Oil pressure switch: signal un feasible
type of error:__________(4) No signal or value
readiness flag:_________(16) Test conditions fulfilled
error-statur:___________(35) current fault existing, OBD debounced
MIL-Status:____________(48) fault caused no signal at warning lamp
P-code:_______________P0520 Engine Oil Pressure Sensor/Switch Circuit
followed by the mileage, engine speed, engine cut off time, engine status & voltage at the time of each fault.
Interesting. That may mean your sensor is just dead? Easy swap out at next oil change?
