Devlin,
I've been running Hankook Ventus V-12 EVOs on my ///M for the past two years and am now looking at replacing my rear sets. They have performed exceptionally well and I would use these again...
I checked pricing for these at discount tire direct and the front set 225/40s are currently at $147.00 ea.
http://www.discounttiredirect.com/direct/tires/hankook/size/viewProductDetail.do?ra=%2Ftires%2Fhankook%2Fsize% 2FviewProductResults&pc=11394&ar=40&rd=18&cs=225
the rear 255/35's are currently at $197.00 ea.
http://www.discounttiredirect.com/direct/tires/hankook/size/viewProductDetail.do?ra=%2Ftires%2Fhankook%2Fsize% 2FviewProductResults&pc=11405&ar=35&rd=18&cs=255
Just putting this out...
On a 8.5" 10mm makes a huge difference. When you get to that point, you need to factor in tire squirm as well as sidewall deflection.
There are multiple studies shown that trying to fit the biggest tire on a wheel results in less optimal performance. This is why I'm only running 265 when I can easily fit 275s
+1 on the V12s. I ran them on my E46 and will be running them soon on the M as DD tires.
+1 on the V12 Evos. They are cheap and perform quite well, but are not for winter use. I don't see any reason to put no-seasons on your car anyway, unless you take road trips up north during the winter.
I was going to go with the v12's as every one down here runs them but I do take occasional trips up north during the winter and the last time I did that on summers my E36 ended up on the side of 95 on a ditch because I had absolutely no traction.
This is really the only reason I want to go with all seasons.
Plus even though this is Florida I do still get freezing temps (I have seen it snow here) or at least very close to them on the rare occasion.
I'm getting new tires in the next week or so and I will probably go with the contour dws or Michelin pilot sports. Leaning towards the pilot sports right now because I live Michelin tires.
I have a question about rims though. I have stock 135 rims and continue tires on them now. Everyone here says that the zhp has a staggered setup and the rear rims are 18x5.
Tire rack doesn't recognize this when I look for tires. The option for oe tires says they fit on 18inch rims not 18x5. (in the rear).
I went outside to I investigate and measured both front and rear rims at 19.5 from top to bottom of rim. (not including the tire) obviously this isn't the proper way to measure rim size, but if the rears were in fact bigger, wouldn't the measurements differ?
The tires in the rear are obviously wider (you can an visually tell).
So I'm obviously missing something here.
Sent from my VS910 4G using Tapatalk 2
Tire rack does have an option for the 330i with Performance package its in the drop down menu.
Standard ZHP rims should be 18x8" in front and 18x8.5" in back. Measuring the externally visible lip of the rim would give you bigger numbers.
