Hey all,
My driver's door fails to unlock with the key (remote or manual turning method). Otherwise everything is fine (it can lock with remote or key). I'm thinking some linkage arm broke? The only way to unlock the door is to pull on the door handle from inside the cabin. It's a PITA, I have to climb from the passenger side or roll down the windows every time I lock the car.
I'm assuming the actuator is fine since it can be remotely locked and makes noise on unlock (I think it makes the appropriate buzzing noise, hard to tell with all other doors unlocking as well). The manual key operation should always work even if all batteries (key and car) are dead right? What could be the issue? Is there a DIY?
Thanks,
