Copy......I agree with 15-20 miles.
This may just be attributable to the brand of oil you're using.....
Years ago my old boss had a Chevy pickup with a small block in it and every time he'd make the 200 mile trip during the winter to visit his daughter the underside of the hood would be splattered with mayo from the breather/oil fill tube. He was running Pennzoil dino at the time and switched to another brand (Havoline maybe?) and it completely stopped spitting mayo after the change of oil brands.
Barry
Ryan.......That just doesn't look right. I don't care how much a car is driven. I would look into CCV valve issue.
Can't moisture like that "Hydro-lock" an engine?
I thought I read somewhere that the yellow goop is a result of very short trips before the car can completely warm itself up. It takes the car to get warm before the CCV can fully start doing its job and recycle the moisture. I would guess that changing out the CCV system would resolve the issue, and to avoid taking very short trips in your car from a cold start.
As far as hydro locking the engine? I'm not sure if the goop would do that. I guess if it gets bad enough it would cause some problems for sure.
CCV
