Thanks, I'm guilty of not coming on here enough if at all. Now that I finally bought the Tapatalk app for my phone I will be on a ton more.
Huh, that's a pretty good idea...I'm sure I'd forget too, though!
It was around 40* here this weekend, and I drove the car a little more than usual. Goop is almost completely gone, and the car's running noticeably better. So I'm getting less concerned about things.
My old car has that simple hose and PCV valve, but all crankcase vapors go back into the intake to be burned--no separator. Draining separated oil to the pan would require a 2nd hose, or a total of 3 connections (one crankcase, one intake, one drain). Does our CCV have 3 or 4 connections? If 4, what does the 4th do?
Yep, that's what most engines do, burn the blow by. Not sure recycling is a) worth the trouble and b) won't that contaminate the oil with fuel? I've seen engines fitted with a catch can. Isn't that what GAS is working on?
