Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Coolant leak
    Jan 2013
    Central California
    Coolant leak
    This really pissed me off. I was working under the car and I barely bumped the tranny cooler that attaches to the bottom radiator. Yes, I have a steptronic tranny. It now leaks coolant right next to the cooler on the plastic bracket.
    Does anybody have any insight into this?
    Jul 2011
    Long island, New York
    You may have cracked a piece of the plastic. How much of a leak?
    It was most likely brittle and you bumped it just right. Better to swap now, vice find out on the road.
    Jul 2011
    All cooling system parts are the a Achilles heal of this exceptional ride. Plastic sucks. At least not as much plastic on the e46 as the e36.
    Jan 2013
    Central California
    It's drips one drop every two seconds. If I push on the tranny cooler I can change the rate of drip.
    Dane, do I have to swap the entire radiator for this?
    I think it's the mounting plate that is leaking.
    Jan 2013
    Central California
    See below. Maybe I am missing a screw. This unit has always had a slow leak but I made it worst by bumping it.
    Salt Lake City, UT
    I think there is supposed to be a screw/clip there. I remember putting one in there when I was putting my front end back together.
    Salt Lake City, UT
    You could JB weld the crack as a delay if you need a little time.
    32.8 N, 117.3 W
    Quote Originally Posted by Avetiso View Post
    no... just buy the train station, they're not very expensive
    Jan 2013
    Central California
    I have looked at posted pictures and see many without a screw but then I saw this diagram posted:
    Part number seven looks like a bolt should be there. Am I reading this correctly?
  1. What is this leak?
    By yura in forum Mechanical | Troubleshooting
    Last Post: 10-20-2013, 12:50 PM
  2. Coolant leak - temp sensor o-ring
    By Pip in forum Mechanical | Troubleshooting
    Last Post: 12-12-2012, 07:10 PM
  3. Coolant Leak From Temp Sensor on Lower Radiator Hose
    By VaTechZHP in forum Mechanical | Troubleshooting
    Last Post: 04-26-2012, 06:08 AM
  4. Coolant leak, temp sensor function question?
    By Whitexi in forum Mechanical | Troubleshooting
    Last Post: 03-06-2012, 07:03 PM
