Car has been throwing an intermittent low coolant light, but the car hasn't budged at all from center (I know its not very accurate) over the past few weeks.
I topped it off with some coolant, only to then realize it had dumped out while I was at work one day.
Today, I actually spent some time messing around with the car and figured I'd take a look at the cooling system to see what was going on.
The car was warm from just driving and when I took the top off, I didn't see much in the expansion tank, so I added some to the high level (even thought that indication is cold)
While letting the car adjust and kick out any air that might be in the system, the expansion tank seemed to be "volcanoing" out a bunch of coolant/water mix.
I let this go on for some time and didn't see any change. The coolant would overflow out of the top and what would seem like pulsating with a lot of hissing like there seemed to be a lot of pressure in the system while the car was hot and running.
I have since turned the car off to let it cool down for while and then will recheck the level to see where it settled and then see what happens tomorrow.
Any suggestions on things to check? The entire system was replace last summer, but it might look like the upper radiator hose is weeping a bit which I'm planning to replace shortly.
Here is a video of what the car was doing. Click the image and it might work? I've never tried to post a vid before!
Thanks!
