Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
    If I were to fix all oil leaks and prevent future ones, which seals/gaskets/clamps would you replace?
    So now that I think I'm over my starting issue, I'm seeing the tell tale signs of oil leaks with drops being present on my garage floor.
    I'm already factoring in the OFHG, VCG but trying to determine which others should be done, while I'm there.
    Pan Gasket? PS lines? Anywhere else? I'll try to gather some pics later if I can of where my leak is. Def. drivers side and likely the OFHG is the main culprit. But if I'm already in there doing these things... I'd like to get all of them done.
    Also, on all of these. OEM BMW parts only? German OE parts?
    On the preventative. I'm at 142k miles and climbing. I'm sure she's due for some that may not be leaking yet, but are common to do so.
    I would just do VCG (do plugs, and VANOS), and OFHG. I would not do PS, or pan gasket "preventatively"...but that's me.
    Victor Reinz should be fine on VCG (or BMW) and I think I just got the BMW gasket for OFHG.
    DW, just to clarify... you wouldn't do it because of cost? Time to get it done? Difficulty?
    I go on 2 week rotations at my office and have a work vehicle during that time. So I can have the car down for 2 weeks at a time.
    @ Vanos. Besian systems. PN BS001 for seals and BS002 for rattle kit?
    Jun 2012
    Montreal, Canada
    Dave, while doing OFHG, replace VANOS oil line, 2 bolts, and 4 crush washers. It's around $45 for everything, but if it's not already leaking now, chances are it'll start soon.
    VANOS Oil Line - Cohline #11361705532
    Bolts - BMW #32416852469 x2
    Crush Washers - Victor Reinz #32411093596 x4
    Re VANOS, you can do Dr. Vanos too. Mine was done by PO and that was the company they used. Car runs perfectly.
    PS lines: trim and reclamp at reservoir. Replace reservoir cap o-ring. Cost: 2 universal clamps and $1 for o-ring (BMW #32411128333). Flush the fluid with any synthetic Dex 4 ATF while doing that, it's way more convenient with the hoses off the reservoir.
    Alex'16 Melbourne Red 328d Touring
    Quote Originally Posted by Dave_B View Post
    Cost Vs. Benefit is low Imho.
    Sent from the HTC DNA, Williamsburg, VA and USA
    Oil pan at RealOEM is 48. ECS has it for $27.
    I can't imagine PS lines are terribly expensive.
    Time? Pain in the A$$? Those I'm not so much worried about. My "sanction" is my garage if you will.
    They have very low failure rates on e46, and even then, failure is typically a drip, that can be a future repair.
    But...
    OMG... If you must.... Just dhu eet!
    Jun 2012
    Montreal, Canada
    PS lines are quite expensive, and you need a special tool to unclamp them. Most frequent drip location is at the reservoir, hence why I recommended new clamps and that's it. But of course... Your call
    Oct 2011
    Silicon Valley
    Agree with Dane, don't replace PS lines as PM, but do check if they're dripping. IIRC, there are 4. Two of them connect to the cooling coil and require the special disconnect tool, or creative use of multiple pliers. The high pressure line at the bottom (from pump to rack) is the most expensive and connects with one big (19mm?) banjo bolt and the other end might require a big (17mm?) flare wrench.
    Jan 2013
    Central California
    I know I'll take heat for suggesting it but before I'd start replacing gaskets I'd first try retorqing stuff like OFH, VC and oil pan. I guess I'm cheap but I like to keep things simple.
  1. VANOS seals and VCG
    By Alobi in forum Mechanical | Troubleshooting
    Last Post: 11-14-2012, 07:37 PM
  2. So ummm, don't neglect small water leaks...
    By Rovert in forum General -- ZHP Related
    Last Post: 02-24-2012, 01:37 PM
  3. Seals and Rattle Kit
    By pleasecorrupt in forum Maintenance
    Last Post: 10-19-2011, 05:46 PM
  4. Replies: 13
    Last Post: 08-28-2011, 09:58 AM
  5. Baby Seals...
    By C Withers Media in forum Everything Non ZHP (the place for non-ZHP photos)
    Last Post: 05-24-2011, 01:34 PM
