Hey guys,
So 3 weeks ago, I replaced the following:
- Water pump, idler, A/C tensioner, belt tensioner pulleys
- 2 belts
- Alternator
- Radiator
- OFHG, VANOS oil line
I also flushed my power steering fluid with Redline D4 ATF, and flushed my coolant completely (block, ET, radiator) and filled/bleeded with BMW Antifreeze 50/50 with distilled water.
Since then, my car has been butter smooth, except for one thing. When under load at very low RPM, there's a metallic rattling that I can't pinpoint.
https://www.dropbox.com/s/44z675ey9f...%2001%20PM.mov
Sorry for the crappy video... but the sound is the most important. I was slowly engaging the clutch in reverse with the handbrake on with no throttle. It essentially happens whenever there is load on the engine and the car is under 1000 rpm. Sometimes happens at idle too (~700 rpm). Besides this noise, the car accelerates and runs perfectly. All fluids are topped off.
I made sure all 4 pulleys were tightened properly and the belts aligned properly as well. I re-tightened everything I could from the top.
Does this sound like something internal to the engine ? It sat with the front jacked for 10 days, and when I started the car for the first time, there was some ticking while the oil re-circulated in the engine. Hopefully I didn't damage anything.
Idea #1: I'm thinking it could be the metal belly pan, as I took it off while I tried to find the coolant drain plug on the block, and I might not have tightened the bolts enough.
Idea #2: It could also be a defective pulley, but stupid me threw the old ones away because I didn't think. There is zero squealing of the kind typically attributed to pulleys. Can I damage anything if I remove both belts and run the engine for 10 seconds to see if it rattles ?
Idea #3: I have the URO aluminum water pump pulley, if it changes anything. Maybe it just vibrates more.
Idea #4: I lost one of the airbox to MAF clips somewhere in the engine bay, and I can't locate it. Maybe it's stuck somewhere and causing this ?
Thoughts ?
