Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Quote Originally Posted by LivesNearCostco View Post
    Good luck! I am up soon to to tackle the radiator replacement on my E36. I've replaced ET, water pumps (though not on a BMW), radiator hoses, thermostats, and heater hoses, but never replaced a radiator before. Still debating if I can re-seal the oil pan myself or if that needs to go to a shop.
    if you have done all of that, a radiator is easy. it just involved careful filling and bleeding of the cooling system, that's it. you can do it.
  2. #22
    Ordered the parts for this DIY.
    Got the following:
    (1) Febi Driveshaft Flex Joint - $46.19 - Part number 26117511454
    (6) OE BMW Flex joint Lock Nuts - $8.64 - Part number 26127536563
    (1) OE BMW CSB - $72.46 - Part number 26127501257
    (1) OE BMW Butyl Tape - $3.78 - Part number 26127511140
    Total Cost in Parts - $131.03
    I went with the Febi Flex Joint (Guibo) since it was much cheaper then a OE Genuine BMW unit which is $141.49. After examining it, I noticed that the BMW logo is ground off the Febi Unit so its as close to a Genuine part as possible.
    As far as the actual CSB, Rein ($23.99) and Febi ($39.39) were an option and cheaper but I was not able to find good information if the quality is close to OE or not. So I spent a but more on an OE Genuine BMW CSB since this is the most important part of this job.
    Wish me luck...
  3. #23
    What's prompting you to do this? Is there a knocking sound or some sort of delay in the driveline?
    Good to know on the Febi Guibo, I'll store that info away for later.
    Wish me luck...
  4. #24
    I replied back in my project thread.
    But the vehicle has visible cracks in the guibo and a vibration which I am guessing is from the csb. Or at least I hope but if the csb fails, the drive shaft will flop around in the carrier.
    As far as mileage, I don't have an idea to when these parts fail.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  5. #25
    Oct 2011
    Silicon Valley
    yes good luck and may the Schwartz be with you, if your car is black!
  6. #26
    Oct 2015
    That's how I replaced my guibo last year. It had visible cracks. I wasn't sure at what point do I have to change it and since the part is affordable, I changed it right away. Mileage on the original gioubo was 139k.
  7. #27
    Close Enough. Black Sapphire Metallic
    Quote Originally Posted by RUS_ZHP View Post
    Do you recall what condition the CSB was in?
  8. #28
    Oct 2015
    Do you recall what condition the CSB was in?[/QUOTE]
    It was pretty good condition for the mileage. I changed cbs because drive shaft needs to be removed anyways.
    I cannot find pictures of guibo and cbs for the reference.
  9. #29
    Tackled this job today.
    Pics below of the original part with 161k on them. Also the new csb installed and the guibo.
    In my case, I did not remove the exhaust. Little more effort with it still installed but it's doable.
  10. #30
    Very good. Do you notice a difference while driving ?
    2005 IR / black / 6MT
    157,000 miles
  1. FS: e46 Center Support Bearing assembly
    By Lanister in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 03-04-2014, 02:08 PM
  2. Replies: 9
    Last Post: 01-09-2014, 10:29 AM
  3. Driveshaft Center Mount bearing removal
    By Lanister in forum Mechanical | Troubleshooting
    Last Post: 11-14-2013, 12:08 PM
  4. Input shaft bearing or throwout bearing?
    By Stu in forum Mechanical | Troubleshooting
    Last Post: 07-31-2013, 06:29 AM
  5. For Sale: BMW 330 ZHP driveshaft 6MT
    By Marcus-SanDiego in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 02-22-2011, 04:29 PM
