Page 44 of 45 FirstFirst ... 3442434445 LastLast
Results 431 to 440 of 445
Thread: The Oil Thread
  1. #431
    I thought it was the Mobil 0w40 that had the LL-01 certification and not 5w30?
    But I agree with BP. You can send it to a testing lab after using it, to see how things are working.
    Correct. Mobil 1 0w-40 had the certification and then it got removed. 5w-30 never had it.
    Also this is a good article in regards to oil suggestions from Redline and Bimmerworld
    https://www.redlineoil.com/tech_article.aspx?id=3
  2. #432
    Apr 2015
    Wilmington, NC
    Ok thanks. I knew that the euro formula was good, but prefer 5w30. I read that long article by the engineer who worked with oils and explained a lot. From what I gather the closer the winter and regular weight is the better. In NC there is no need for 0w seeing as how we hardly ever get below 0C.
    I plan on sending my oil to get analyzed and trying a few different ones for comparison sake. Is there a thread somewhere of a Blackstone results compilation?
  3. #433
    VA/DC
    Yep, sorry, had my weights mixed up. And I still use 0w40.
  4. #434
    Jul 2017
    central VA
    I’m in need of a top off and the PO used liquimolly 5w30 when he did OFHG and oil change prior to my purchase. I’m only 2k in and not ready for an oil change. Should I just stick with what he used for my top offs?
  5. #435
    Quote Originally Posted by droman81 View Post
    Ideally yes.
    Liqui Molly is some good stuff.
  6. #436
    Aug 2014
    Leesburg, VA
    Quote Originally Posted by hcbeck2689 View Post
    Take a look at the Bob Is The Oil Guy site - you can read about oil until your eyeballs bleed!
    https://www.bobistheoilguy.com/forum...s.php?ubb=cfrm
  7. #437
    Apr 2016
    Katonah, NY
    Its been almost a year since the last post here and I'd getting ready for my first oil change. What are people using nowadays? There wasn't any talk about liquimoly? is it true thats mostly because its a bit newer to NA?
  8. #438
    I been using the Liqui moly oil change kit from fcpeuro.
  9. #439
    Apr 2016
    Katonah, NY
    5W 30 or 40? is 30 typically used for gas milage? Thats how I'm seeing them as advertised but just wanted to see what others have experienced.
  10. #440
    5w30. And I also add liqui moly ceratec
    Quote Originally Posted by joeybananaz18 View Post
Tags for this Thread
