Im planning on getting 12.5mm/15mm (F/R) spacers from TMS,
http://www.turnermotorsport.com/c-14...l-spacers.aspx
and after some more reading (and of course thanks to Charlie that did the stud conversion on his magical ZHP ), im now leaning on doing the same thing instead of getting longer bolts together with the spacers. Which studs do you think is the best? what size (for 12.5/15mm spacers)?
What do you guys think?
Also Charlie, if you read this, can you please share some info on those studs you got from Rob and Kristen?
