Thanks for this, folks. Yes as regards the cover on the interior of the door. You remove that to get access to the mirror mounting, right? If so: how?
Other tweaks: see my profile
review this thread here
http://forum.e46fanatics.com/showthread.php?t=675377&highlight=m3+mirror+retrof it+sedan
when I installed my OEM M3 side mirrors onto my ZHP I used this thread as a guide....
PERFECT! Thank you!
Just did this conversion with no DIY. Accidentally completely severed the ribbon cables on the driver side. Successfully scraped them and soldered back together. On the passenger side I actually did away with the large piece of plastic inside and mounted my motors directly to the rectangular base, with a spacer in between. Got my mirrors for 200 as well
Modification ThreadOriginal Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)European Auto Source TechInstagram: @CarbonZHP
Good job! I wasn't so fortunate. Even after soldering, my motors are still dead
I scraped the insulation off the ribbon cables, overlaid, and carefully soldered. Luckily I had a new iron with a very fine point. Amazed they still work
Sent from my XT1585 using Tapatalk
I did the same procedure and verified the connections with a multimeter but no joy
Did you have the plastic cable heads on correctly. When I originally tested they didn't work but I since I had pulled the pins out of the head to feed them through, I tried switching them and it worked
IMG_8537 by 8two8automotive, on Flickr
IMG_8538 by 8two8automotive, on Flickr
I Just got some Imola M3 side mirrors for my sedan. $350 shipped out of ATL on craigslist. I cant wait to do this DIY! Thanks for posting this!
