Results 1 to 10 of 18
    Apr 2013
    Tahoe
    Anyone using E90 strut mount/drop hats?
    Was told by a tech I could use these for a minimal drop. I think he said you can get a 1/2".
    I'm just starting to put together a 'suspension refresh' using stock springs/sway bars.
    Here's is my list so far:
    Front:
    FSD struts
    E90 strut tops/ Plates'
    Z4M fcab
    F Control Arms
    Sway Bar bushings
    Rear:
    FSD shocks
    Rear shock mounts/plates
    M3 rtab/Limiters
    R Sway Bar bushings
    *Maybe endlinks F/R..not sure but if they show any wear they'll get replaced
    Anything you'd add to this? I'm calling it my Average Joe ZHP Suspension refresh part 1. Part 2 will include springs/sway bars. All aimed at making a good performing DD for the average Joe (or Jill)
    One more question. Does Pro Flex make bushings for our stock sway bars? I have Pro Flex sway bushings on my stock xi front bar and it does make a dif'
    Request P/N for drop hat.
    Apr 2013
    Tahoe
    #3130 6775 098 (97) lemforder
    Oct 2011
    Silicon Valley
    I think PowerFlex makes poly swaybar bushings in 23mm and 24mm (and other sizes), and the stock front ZHP bars is 23.5mm. (Stock rear might be 19mm.)
    32.8 N, 117.3 W
    my buddy is and he loves them
    Apr 2013
    Tahoe
    I guess I could stuff the 24'mm into the 23.5.
    Isn't the rear bar 18.5?
    Jacksonville, Florida
    Quote Originally Posted by LivesNearCostco View Post
    I bread somewhere on e46 fanatics that a guy used the 23mm bushings on the zhp sway bar. They were tight but they did fit.
    I also read from I think vorshlags site that poly bushings are really bad. I don't know enough to dispute their claim, just throwing this out there.
    You have mount plates on your list. Do you mean the reinforcement plates? Also if that koni kit your getting doesn't come with spring pads dust boots etc, ecstuning has a kit for like $300 something that comes with all the hardware you need. Gaskets OEM reinforcement plates for front and rear along with dust boots oem rear shock mounts spring pads, seems like a solid deal so I picked that up when I bought my h&r touring cup kit.
    List looks good op.
    Sent from my Nexus 4 using Tapatalk 2
    ~Rob~
    Apr 2013
    Tahoe
    He used 23mm bushings on a 23.5 bar? Don't you mean a 24? I believe my xi bushings were 1/2 milleter bigger than the bar and they were no problem to press in
    Oops I forgot rear shock mounts..
    yeah I meant the reinforcement plates F/R
    Poly is OK if you lube it right. The ones on my xi have been on for over a year with no squeek'. It's all in the quality and amount of grease. Plus I make sure the car is on the ground 'till I fully tighten the mounts.
    Apr 2013
    Tahoe
    I fine out now that E90 drop hats part # split in 6/08'. I'm curious to know which ones fit E46..before the split or after?
    I've ordered most of the stuff on the list. Still sniffing around for sources for>
    Lemforder Lower Control Arms, Strut reinforcement plates, rear shock mount plates and Z4M LCA offset bushing. So many choices for vendors...If you've got a favorite vendor let me know as I'm just buttoning up all this ordering before the end of the day.
    *Note: I went ahead and ordered POWERFLEX Sway bushings...24mm F/19mm R
    Apr 2013
    Tahoe
    That part # I posted earlier is wrong.doh
    I called the dealer in Reno on the z4m coupe LCA bushings and they're price is 105 per side for the bushing w/bracket... Far cry from 56 for both
    The list just keeps growing. I added, StopTech brake lines,F Sway Bar links and Tie Rods. I think that should cover it....yeah right haha
  1. Tach and speedo gauge needles drop when opening door
    By Oli77 in forum General -- ZHP Related
    Last Post: 07-18-2014, 10:19 AM
  2. For Sale: 2005 BMW 330Ci ZHP 6 speed manual 72k $17,600 Price Drop
    By Neil22 in forum BMW 330 ZHPs For Sale (vehicles only)
    Last Post: 06-21-2012, 11:21 AM
  3. For sale: E46 BMW Airbox + K&N drop in
    By Dotpage in forum Other Automotive Classifieds (No ZHPs)
    Last Post: 03-31-2011, 12:52 PM
  4. K & N Drop In Filter -- Thoughts & Discussion
    By danewilson77 in forum Mechanical | Troubleshooting
    Last Post: 02-27-2011, 07:42 AM
