Results 1 to 4 of 4
    ND
    Easy DIY brighter led brake light mod (E46 BMW) doityourself
    I'd like to try this but I'm always nervous about cutting into the factory wiring harness. It makes it so ALL of your taillight LEDs light up when you brake. The way it is from the factory with the Adaptive Brake Lights the outer ring only lights under heavy braking....
    http://www.m3forum.net/m3forum/showp...64&postcount=4
    before.....
    after......
    Barry
    Thanks
    Valparaiso, IN
    You should be able to turn this off in ncs expert without making any physical changes. Changing BFD_ON to nicht_aktive should do the trick. I can't confirm this though since I don't have the fancy led lights
    ND
    Quote Originally Posted by ryankokesh View Post
    Interesting. That would be nice, save from cutting into your wiring harness.
    Thanks
  1. Replies: 35
    Last Post: 05-15-2015, 07:19 AM
  2. Replies: 17
    Last Post: 04-11-2014, 06:58 AM
  3. HID fog light retrofit doityourself
    By JupiterBMW in forum DIY
    Last Post: 03-13-2014, 07:40 AM
  4. E46 E-Brake adjustment doityourself
    Last Post: 02-22-2014, 07:31 PM
  5. Resetting Oil Service Light doityourself
    By ryankokesh in forum Maintenance
    Last Post: 01-24-2014, 05:03 PM
