Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: Help!!! Coolant leak through transmission
  1. #21
    Jan 2014
    Miami, FL
    SOLVED!!!
    The two plastic coolant pipes in the side of the engine were totally destroyed.
    I replaced everything on the cooling system and vacuum system, cleaned throttle, idle valve and DISA.
    The car runs like new!
    Sent from my SM-G986U using Tapatalk
  2. #22
    Damn...glad you figured it out! Can you post the part numbers of the broken hoses?
  3. #23
    Aug 2014
    Leesburg, VA
    #s 6 & 8 are the hard plastic lines:
    06 Water pipe (1) - 11537502525
    08 Heater inlet pipe (1) - 11531705210
    (#7 O-rings come on the new lines.)
    https://www.realoem.com/bmw/enUS/sho...diagId=11_2200
  4. #24
    Jan 2014
    Miami, FL
    Exactly!
  5. #25
    How often do they go bad? I know cooling systems on the front of the engine fails like clock work every 100k but I havenít seen anyone mention these.
  6. #26
    Aug 2014
    Leesburg, VA
    How often do they go bad? I know cooling on the front of the engine fails like clock work every 100k but I haven’t seen anyone mention these.
    I've owned my 2003 530i since 75k miles. Replaced all that same stuff in fall 2019 at 140k preventatively - most parts were original.
  7. #27
    Good news!
    Sent from my SM-G998U using Tapatalk
  8. #28
    My ZHP had over 170k before I replaced them. They were brittle and broke into pieces as I was removing them. I would say 150k would be a good interval. Or every other cooling system overhaul.
    -Corey
    2003 Blue ZHP Sedan @ 210k
  9. #29
    Iím at 204k and havenít looked at them. From what youíll are saying, itís way over due.
  10. #30
    Jan 2014
    Miami, FL
    I'm at 145k but it's a South Florida car so it always runs in very hot weather, the pipes where totally burnt out.
  1. COOLANT LEAK BUT WHERE?
    By Smilez in forum Mechanical | Troubleshooting
    Last Post: 10-12-2016, 01:23 PM
  2. Weird coolant leak...
    By ecrabb in forum Mechanical | Troubleshooting
    Last Post: 06-25-2016, 11:02 PM
  3. Coolant Leak
    By san in forum Mechanical | Troubleshooting
    Last Post: 11-24-2014, 06:46 PM
  4. Coolant leak
    By Dave1027 in forum Mechanical | Troubleshooting
    Last Post: 04-27-2013, 11:24 PM
