Oh k lol gotta ask shiaaatt
Thanks all for the responses. WP was replaced OEM about 3 years ago and has about 25K miles on it.
I can feel the sound over the center of the engine (all over the valve cover) not more so towards the VANOS. Definitely nothing over to the intake side.
I placed a wood-stethoscope over the VCG bolts and can hear metal sounds transfer. That sound is not louder toward the VANOS (could still be it though).
I would love this to be the idler pulley but it sounds like its throughout the engine more so than the front.
I thought VANOS sound was more like a rattle. Also, would my MPG be bad if VANOS were the culprit?
The normal audible VANOS sound is a rattle correct.
Hmmmm so maybe an issue with the exhaust can?
How does it run and drive other than the noise?
Run and drives and pulls well I think. MPG at 23.7 in city.
Yes maybe cams. But their "timing alignment" is driven by the VANOS correct?
If i increase RMP, obviously sound increases in rhythm.
My guess would be a/c compressor / clutch?
A Venza just isn't the same as a ZHP.
Why u say ac compressor ? Just wondering
Wow. Thats definitely piston noise. Not a bearing or a vanos rattle.
Oli, pull your MAF Oli and see if the noise goes away.
Sent from my GS3.
Porsche 944 Turbo Build
My ZHP Build 2004-2014 RIP
OK. So start it up and then remove maf connection? Or remove maf and start it up?
