So I just had my front end stuff done, tie rods, bushings, all that. My problem still exists.
It does this on and off every few minutes while driving. It gets bad for a minute, then goes away a little, then comes back, then goes away. It will be ok for a few minutes, then it starts to bump bump bump bump. Bump in the steering wheel, car, everything. Bumping. When this bumping gets bad, and I hit the brakes, the car feels like it's floating and can pull to one side or the other. This is scary. It also tends to "hold back". It's like something is stuck and not allowing the car to roll freely. You can feel something "holding the car back". Almost like if the e-brake was on just slightly and you get the feel of something holding the free motion of the car back.
I'm freaking out.
I just dropped some good cash and turns out it's not the main problem. Could this be failed rear bushings? Anything specific? The car is parked once again.
