Porsche 944 Turbo Build
My ZHP Build 2004-2014 RIP
^Yup. Read the procedure at the Beisan site and get knowledgeable on the procedure. It will help.
You could knock it out yourself, or do it at the meet. We can support.
So, a question - does the vanos problem normally cause the same hesitation at full throttle? I ask because I have had similar problems on a previous car, and it ended up being the fuel mixture causing hesitation due to incorrect o2 readings at part throttle. Once at ~80% throttle the car would go into PE mode (power enrich) and used a preset mixture setting instead of the o2 sensor, and the problem went away.
A simple way to check without having to open the hood is to try to duplicate the problem when the car's cold - I'm not 100% sure the e46 is set up the same way, but on my old car the ECU would ignore o2 readings for a short time while the car heats up (and my problem went away then too).
I have no hesitation if accelerating over half throttle maybe its closer to about 60% throttle, I dunno. It does it once warmed up, not really much when cold. But I have a faint but distinct rattle at idle as well. I'm getting about 4-5mpg less than I normally do. After reading the Beisan thing, I'm pretty sure its Vanos.
My garage: 08' Alpine White 135i Coupe putting out 405 wHP to BOTH rear wheels. 05' LeMans Blue X5 4.8is that I like to call Truckmeat. Socketheads 05' Dinan tuned ZHP, and a few Hondas to keep it real.
