So now that the daily temps are dropping, I've noticed that my water temp isn't getting to the center of the gauge. It makes it to about 10:30-10:45 position, but that's it. What is this a sign of?
Wes
Wes
Wes
Time for a new thermostat. Your old one is not closing enough, resulting in excess coolant circulating and thus lower engine temperatures. Though not an emergency, I'd tend to it sooner than later.
^ yup
Stuck open thermostat or bad o-ring for the t-stat. Cheap and easy, get a new thermostat.
Better stuck open, than stuck closed.
Porsche 944 Turbo Build
My ZHP Build 2004-2014 RIP
Yup. Thermostat. Luckily, that is open, but if it sticks open, then it can stick closed. Replace asap. Mechanic 300 or so.
Sent from my DROID2 GLOBAL using Tapatalk
09 135i Msport 6mt
04 330i ZHP (sold)
David
Yep. What they said. T-Stat. I had exact same symptoms on my 93 325is and took it to a mechanic who told me it was something else. I said, lets try a TStat first. He did & prob solved.
Brembo Rotor
^Did not know it was that expensive, every other car I've dealt with is like 20$ -30$ for the t-stat, is there any way to manipulate the part to act like a normal one?
Brembo Rotor
