Battery...either it isn't charged or the Alternator is bad.
Just a guess...
Just a guess...
Porsche 944 Turbo Build
My ZHP Build 2004-2014 RIP
This actually sounds very plausible. Car wouldn't start with a failing fuel pump right? I was originally thinking the fuel filter might be clogged.
If you kept trying to start the car and the alternator was bad, you should be able to measure the voltage on the battery and notice the drain right?
Its a new battery, not ruling it out but its unlikely. Alternator is a good suggestion.
I did think fuel filter also, not sure how I would test that except for just change it, might have to. I was also thinking about testing the voltage, although it cranks strong every time i have tried to start it.
Going home at 1:30 today and will begin diagnosis.
Hey good to know! Also he says there could be only 3 problems causing not to start.
1.Gas is not burning - Bad gasoline
2.Gas pump is dying.
3.Electrics like spark plugs.
@newjack
It works because when you press the gas half way pump starts building pressure and pushing gas in to the engine. Another trick if your car doesnt work in realy realy cold weather do the same thing and should start right up.
