There's a 3.46 from a 325 on e46f right now if someone is feeling adventurous
http://forum.e46fanatics.com/showthread.php?t=1007697
Only $185.00
2006 CiC 6MT
ZHP, Cold Weather, Xenon
I have a 3.38 from my parts car.
Sent from my SPH-L720 using Tapatalk 2
In the market for an E90 M3
Sooo... what do these all really help with? And do you lose 6th gear?
Matt/Matthew/Belvin
2003 ZHP Sedan, 6sp, Jet Black/Sand with Black Cube
*Amber Army*
Well... it does in a sense. You will gain acceleration with the shorter gearing, but lose some top speed in each gear. You will not lose an entire gear, just speed vs rpm in each gear will change vs now
An important thing to note is that your gas mileage will suffer because of the higher revs at cruising speed. This site will calculate what the revs will be at any given speed:
http://www.bokchoys.com/differential...calculator.htm
This may not matter to some, but just having higher revs while on the highway can be irritating depending on the circumstances.
Im losing 2-3mpg difference with my 3.62. Used to get 29-30mpg consistently, I'm getting closer to 26-28 depending on how hard i drive, which happens more often since I'm in the powerband quite more often..
IMO, as long as the RPM for 70mph in 6th gear is near 3000rpm, you should have minimal impact on mpg unless you drive it harder.
