Results 1 to 4 of 4
Thread: M3 Fuel Pump
    Apr 2013
    Central Jersey
    M3 Fuel Pump
    I was cruising the old classified section and came across and M3 fuel pump assembly for $100. Seller says it came out of a car that had 50,000 miles on it. Now here comes the question....
    Could I swap and M3 Fuel pump with the one out of my 330i? What would be the benefits/disadvantages of doing said swap? What is the difference in fuel pressure between the two pumps if there is any? Is it even worth doing the swap?
    Love the forum, thanks in advance guys!
    Sep 2011
    San Francisco, CA
    No. The fittings are difference and the fuel pressure is actually lower in the 330i as well. Not worth it. The only reason to do this is if you are doing an S54 swap which involves replacing all the fuel hardlines too.
    Philadelphia
    It can be done, but there's no advantage unless you're boosted.
    Baton Rouge, LA
    You can swap in the M3 fuel baffle (16 11 2 229 656). I would recommend making sure you are quite low on fuel if you try to swap it out.
    2003 E46 Silver Grey 330i ZHP 6MT
    Dr. Vanos, BMW Performance SSK, Meyle HD RSM FCA & FCAB, E9x M3 motor mounts, Black kidney grills, Eagle eye LED tails, AFE Stage 1 Intake, E92 ZKW reflector bowl retrofit, Umnitza Orion V2 Opaque 6000k Angel Eyes.
  1. When to change fuel pump, fuel filter?
    By johnrando in forum Maintenance
    Last Post: 11-17-2014, 10:57 AM
  2. BMW 330i ZHP fuel pump DIY doityourself
    By danewilson77 in forum DIY
    Last Post: 03-17-2014, 10:25 AM
  3. Fuel pump noise?
    Last Post: 02-27-2014, 04:29 PM
  4. Fuel Pump
    By GSEN820 in forum Mechanical | Troubleshooting
    Last Post: 10-17-2011, 03:16 PM
  5. Fuel pump/filter replacement?
    By Cadeez in forum Maintenance
    Last Post: 08-25-2011, 04:44 PM
